1987 Chevy Van EGR Testing
167,000 MILES • V8 • 2WD • AUTOMATIC
PUBTECH
I have an EGR error code on the van. When I put a vacuum gun on the EGR with the engine running the vaccuum will not hold the EGR open and does not kill the engine. When I remove the EGR from the engine and use the same vacuum gun the EGR valve holds at approx 8 in. Is the EGR bad or not????
Aug 26, 2010 at 11:07 AM
SATURNTECH9
  • 30,868 POSTS
It should hold more then 8 inches and should hold with the engine running you need a new valve.
Aug 26, 2010 at 11:10 AM
