1979 Chevy Van Ignition coil problems
189,000 MILES • V8 • 2WD • AUTOMATIC
BIGHEART
I got a 1979 Chevy van with the 400 small block, it has the ignition coil on top of the disturber cap, I have replace the coil about five times and I would like to know what could cause the coil too arch from one wire to another, is there a direct feed back that could cause it burn up, if so what could it be, and what do I do about stopping the feed back?
Feb 8, 2008 at 3:49 AM
  • 75,988 POSTS
Check the metal ground strap maybe its missing that goes under the top cover and grounds the coil on the HEI.
Feb 8, 2008 at 5:23 AM
