window wipers not working
VANDURAMAN
V8 two wheel drive automatic 97,000 miles
hi,
My window wipers are not working. is there a fuse or a motor type setup i should be looking at? any ideas would be appreciated.
thanks!
Nov 13, 2009 at 2:10 AM
MIKE H R
  • 3,094 POSTS
Check the fuse, it should be to the side panel on the driver side. To get at it you have to have the door open. If the fuse is bad replace it, Most times it is the fuse. If you find out that it all right then check the wiper switch connections.
Dec 26, 2009 at 3:43 AM
