2006 Chevy Uplander Rotor Replacement
BUCHBRI
Brakes problem
2006 Chevy Uplander 6 cyl Two Wheel Drive Automatic 95000k miles
Do I need to to remove the caliper mounting bracket to replace the rotor. I have the caliper of and hung out of the way but the bolts and the nouting brack are really tight. Does this bracket need to be removed or can I slip the rotor in by just taking the caliper off?
Aug 21, 2010 at 1:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, you need to remove the brake caliper and the caliper mounting bracket as an assembly
Aug 22, 2010 at 8:45 AM
