why does s10 temp go up while idle & ac on ?????
HARLEY15767
I have a 2002 chevy s10 4.3 v6 4x4 with 60,000 miles and when truck is idle in town and a/c on, the temp goes up. just had radiator flushed, new thermo and rad. cap installed but still not solving the problem. Please help. i am at a loss. Thanks Don!!
Sep 19, 2007 at 10:38 PM
WRENCH
  • 57 POSTS
How hot does it get, its okay to have the engine run a little hotter with a/c on, as long as it stays in the safe range, you can check the a/c freon or if in need have it replaced, maybe it just needs a recharge. Your truck should be r134a freon and you can get gauges and r134a your self and check, if it does to get cleaned and replaced recomend a shop do that becouse there is a type of oil in there and you need things to be at the right levels,(and they have a machine that vacuums it out) but to check and top off you can do that. Also check compressor and check for leaks.
Sep 20, 2007 at 1:53 PM
