I HAVE AN 81 CHEVY TRUCK WITH A 350/350.
THE TRANS WONT UP SHIFT.
I HAVE REPLACED THE MODULATOR AND DETENT CABLE. ANY SUGGESTIONS?
Monday, November 12th, 2007 AT 11:10 PM
JASON R
MEMBER
Did you see how mcuh fluid is in the case?Manual automatic?If its an automatic you probably dont have enough fluid. If iits a manual check that the linkage is connected to the shifter. If it is your shifter fingers probably are gone
