truck back firing after valve ajustment
NEWROADHOUSE
I have a 1982 chevy c-10 pick up with 117000 miles. Has a straight 6 250 motor. 2 wheel drive. Was replacing valve cover gasket and decided to adjust valves. After i was completed the motor turns over and wont start. There is some serious back firing happening. Please help me resolve this.
Thank you
Jim
Aug 30, 2007 at 3:22 AM
  • 75,988 POSTS
[quote:b76d9e648f="newroadhouse"]I have a 1982 chevy c-10 pick up with 117000 miles. Has a straight 6 250 motor. 2 wheel drive. Was replacing valve cover gasket and decided to adjust valves. After i was completed the motor turns over and wont start. There is some serious back firing happening. Please help me resolve this.
Thank you
Jim[/quote:b76d9e648f]
You misadjusted it-the valves are opening when not supposed to, in other words its too tight . Manually turn engine over Put the no.1 cylinder on TDC compression stroke-adjust the no.1 and follow the firing order. I would guess the F/O is 153624. When done adjust the ignition timing and curb idle. Note: adjusting the valves will change the ignition timing, its a must you retime it.
Aug 30, 2007 at 10:14 AM
NEWROADHOUSE
[quote:94987b9166="rasmataz"][quote:94987b9166="newroadhouse"]I have a 1982 chevy c-10 pick up with 117000 miles. Has a straight 6 250 motor. 2 wheel drive. Was replacing valve cover gasket and decided to adjust valves. After i was completed the motor turns over and wont start. There is some serious back firing happening. Please help me resolve this.
Thank you
Jim[/quote:94987b9166]
You misadjusted it-the valves are opening when not supposed to, in other words its too tight . Manually turn engine over Put the no.1 cylinder on TDC compression stroke-adjust the no.1 and follow the firing order. I would guess the F/O is 153624. When done adjust the ignition timing and curb idle. Note: adjusting the valves will change the ignition timing, its a must you retime it.[/quote:94987b9166]
Do I need to take valve cover off again and reajust valves?
Thanks,
Jim
Aug 31, 2007 at 12:03 AM
