Transmission/Transfer case
KEGMAN86
Chevrolet, K20 Pickup, 1975, 200,000+, 454CI
Will a 205 transfer case fit onto my turbo 350 automatic transmission. If so, will my drivelines need to be modified?
May 29, 2007 at 9:44 AM
2CARPRO JACK
  • 11,533 POSTS
Honestly, Im not sure. Might want to try a site like trans-dapt, to see if they make an adapter to do this, if they do then you need it. Rock crawling forums would be a great place to find these things out or maybe even a better set up to use. G
Jun 1, 2007 at 12:53 AM
CARNUCK
It depends what the input spline of the tcase is (TH350 is usually 27 spline output but I'm not sure with the 205/203 tcases) I have an NP208C for parts (needs a chain. I'm also calling you about the J10 you have for sale too but no answer)
Jun 21, 2007 at 7:49 AM
