1996 Chevrolet K2500 Tire Pressure
ADIRONDACK2004
1996 K2500 4x4 Extended Cab Pickup, 200,000 kms, 7.4L, What is the correct "cold" tire pressure for this vehicle? Is the front tire pressure suppose to be different then the rear? Unfortunately the Certification/Tire label on the driver's door is unreadable.
Sep 10, 2007 at 6:51 AM
SERVICE WRITER
  • 9,123 POSTS
65 pounds in the front, 80 in the rear.
Sep 10, 2007 at 6:57 AM
Suggested Repair
Set cold tire pressure to 65 psi in the front tires and 80 psi in the rear tires.
Conversation Summary
The owner of a 1996 Chevrolet K2500 asked for the correct cold tire pressure because the door certification label was unreadable, and whether the front and rear pressures differ. The expert recommended 65 psi in the front and 80 psi in the rear.
