hi all my 1990 gmc is timed at 0 degrees btdc if i went to 2 degrees how much performance is gained and would i notice a change in power thanks.
Apr 9, 2007 at 1:49 PM
✓Experienced Mechanic
[quote:3dffd37a9c="indy400"]hi all my 1990 gmc is timed at 0 degrees btdc if i went to 2 degrees how much performance is gained and would i notice a change in power thanks.[/quote:3dffd37a9c]
You want more power use a 10K ohm resistor bridge the coolant temperature sensor connector this will fool the computer of thinking the engine is cold and wants fuel at all times-in other words it won't go in closed loop for the O2 sensor to take over the fuel demand.
Apr 10, 2007 at 10:56 AM
HBAUGH
MEMBER
if you time your vehicle to 8-10 degrees your motor will run better. then make sure your spark advance is working and check to see how much advance you are getting when you rev the motor up.
