1994 Chevrolet S-10 Towing Capacity
MARTYGRAW
Does anyone know how much weight a 2.2l 1994 S-10 can pull safely?
Jun 12, 2007 at 1:29 PM
E40WATER12
  • 522 POSTS
It should say on youre trucks ID tag on youre door, I wouldnt push anything more then 500-600 lbs max. 2.2L motors weren't made for heavy hauling.
Jun 16, 2007 at 9:53 PM
Suggested Repair
Check the truck's door ID tag for the rated towing capacity and do not exceed about 500-600 lbs with the 2.2L, which is not suited to heavy hauling.
Conversation Summary
The owner asked how much weight a 1994 Chevrolet S-10 with a 2.2L engine can pull safely. The reply said the rating should be on the door ID tag and advised not exceeding about 500-600 lbs because the 2.2L was not made for heavy hauling.
