What should I do?
1975 Chevy 1/2 ton pickup-Model C10
Mileage: 160,000
Automatic, 2 wheel drive
Noise: Knocking noise while engine is running. Starts up fine.
I am wanting to sell this truck, but I need to know if I should fix the problem first. I have oil leak, but the dip stick shows oil. Possible oil pump out, but why would I have oil registering on the dip stick still?
What is envolved in replacing the oil pump? What other things should be checked. I want to fix it as cheap as I can in order to sell as a working truck.
Fixing the problem or replace with another engine?
Thank You
Mileage: 160,000
Thank You
Jun 25, 2007 at 7:21 AM
