Oil Leak
MOFARMKID
I have a 89 Chevy 4X4 1500, with just over 200K miles on it. It has been leaking oil over the past few days, seems to just be leaking when I am driving it to work. It seems to be using about a quart of oil every 40 miles or so. Looked under the truck last night and the bottom of the truck is all covered in oil. Someone stated that it was the rear seal that had went out of the motor. I was just wondering how hard that is to change on a 4 wheel drive? On top of that its a standard, just heard that its harder to do repair work on a standard than an auto.
Thanks
Ken
Oct 12, 2007 at 4:41 AM
MERLIN2021
  • 17,250 POSTS
Yes is harder on the 4x4...you need to drop the tranny and the flywheel, then use the sel remover and install, special chevy tool!
Oct 12, 2007 at 5:40 AM
