Knocking in Steering column when I make turns
JWEIMER1968
I am getting a slight knocking sound and motion in my steering column when driving. The noise and motion become worse when I make turns. Is this most likely from bad ball joints or something else? It is a 2005 Silverado 2wd, 45k miles, automatic, V6.
Jun 25, 2007 at 12:55 AM
E40WATER12
  • 522 POSTS
Could be youre outter tie rod ends are not properly lubed with grease, As well ball joints as well, Could get them greased, Could correct the problem.
Jun 25, 2007 at 8:49 PM
GBGTEXAS
  • 46 POSTS
[quote:1548787a6a="jweimer1968"]I am getting a slight knocking sound and motion in my steering column when driving. The noise and motion become worse when I make turns. Is this most likely from bad ball joints or something else? It is a 2005 Silverado 2wd, 45k miles, automatic, V6.[/quote:1548787a6a]
May need to have the intermediate steering column shaft greased. This is a common problem on Chevy's around 2004-2006. If it's not under warranty, should cost around $80-90.
Jul 2, 2007 at 2:46 PM
