1995 C3500 with 88K A/T and rear drum brakes. At low RPM(idle) brake pedal would go to the floor and lose power steering. The belt was good and P/S fluid good so I replaced the hydrolic power booster. since then, same problem. At 1500 RPM or better there are no problems. Should I be looking at the P/S pump next? Ideas?
Oct 14, 2007 at 12:39 AM
