1995 Chevrolet C3500 Idle Brake Loss
DADDYOZZ
1995 C3500 with 88K A/T and rear drum brakes. At low RPM(idle) brake pedal would go to the floor and lose power steering. The belt was good and P/S fluid good so I replaced the hydrolic power booster. since then, same problem. At 1500 RPM or better there are no problems. Should I be looking at the P/S pump next? Ideas?
Oct 14, 2007 at 12:39 AM
MIGHTYMAX11
truck does not have tilt. I have removed the wiper control and cleaned the contacts. Wiring looks okay. I can not duplicate the problem while stopped. It seems to happen when I have been driving for about 20 minutes.
I also have the problem with the door ajar light coming on when I open the passenger side door. The light will eventually go out after about a minute.
Jul 30, 2007 at 1:03 PM
98RANGERXLT
  • 301 POSTS
Take some Brakleen and spray in the lower part of the latch and close doors about ten times and then leave doors open to dry that should solve prpblem
Jul 30, 2007 at 3:17 PM
MERLIN2021
  • 17,250 POSTS
The likly culprit is the return line to the pump is kinked or has an internal colapse!
Oct 14, 2007 at 1:31 AM
Suggested Repair
Inspect the power steering return line for a kink or internal collapse. For the door-ajar light, spray brake cleaner in the lower latch, cycle the door several times, and let it dry.
Conversation Summary
A 1995 Chevrolet C3500 loses brake assist and power steering at idle but works above about 1500 RPM. The belt and fluid were good and a hydraulic power booster replacement did not help. An expert said the return line to the pump is likely kinked or collapsed internally. A separate door-ajar light complaint was addressed by cleaning the door latch.
