When I turn the ignition key on, I hear a "pop" - the 20 amp fuse is blown. I've replaced it numerous times but can't find the cause. When this occurs, I get no reading from the fuel gauge nor the amp gauge to the alternator.
The engine is a 1985 350 1-ton. I have dual gas tanks on the truck. I changed the fuel tank selector switch (this occurred once before and doing this fixed the problem). Any suggestions on what my next steps should be? I have a repair manual for the truck but can't pinpoint what I should do. Your help is greatly appreciated.
Nov 27, 2007 at 3:58 AM
