1993 Chevrolet Silverado Gauges Jumping
LUIS_FLORES60
I just bought a pick up truck chevy silverado 1993 ,130.000,v8
couple weeks ago and once and while when driving all gauges ,battery,gas,temperature,etc.. start jumping up and down like crazy for 2 or 3 seconds then the truck just keeps running normal,then all gauges goes normal again ,and if is night light gooes out, I checked battery connection ,alternator is good any idea what could be the cause of this problem I apreciate any help.
Jun 8, 2007 at 3:37 PM
E40WATER12
  • 522 POSTS
Could either have a ground problem, on the battery, Also could have a corroided battery terminal connections. Also Youre trucks on board ECU could be failing, I would also make sure youre battery is in exc working condition. U need a strong battery to run all youre truck sensors and emissions sensors as well.
Good Luck.
Jun 8, 2007 at 9:19 PM
Suggested Repair
Check the battery ground and terminal connections for corrosion or looseness, and confirm the battery is in excellent condition. If those are sound, have the onboard ECU evaluated as a possible cause of the brief gauge and lighting dropouts.
Conversation Summary
A 1993 Chevrolet Silverado owner reports that all gauges briefly jump and nighttime lights go out for a few seconds while driving, then everything returns to normal. The battery connections were checked and the alternator was said to be good. The expert suggested a battery ground or corroded terminal problem, a weak battery, or a failing ECU.
