chey 1994 c 1500 coolant
HOTDEAL
  • 6 POSTS
1994 c1500, 4.3l eng, 128k miles, 2 wheel drive, silverado package, heavy duty towing package. cut out cataiytic converter, put on duals with glass pack mufflers on duals. have started loosing coolant.problem did not show up till i put the duals on. have slooshing sound in heater core, moisture coming ou both sides of exhaust left heaver than right. no coolant in oil or oil in the raditor. during winter or summer temp gage shows only about 80 degrees and hard to get heat during winter. is it possible that the heater coree is clogged and is causing all my problems? :?: :( :(
Sep 2, 2007 at 7:03 PM
  • 75,988 POSTS
[quote:ee124ee2b2="hotdeal"]1994 c1500, 4.3l eng, 128k miles, 2 wheel drive, silverado package, heavy duty towing package. cut out cataiytic converter, put on duals with glass pack mufflers on duals. have started loosing coolant.problem did not show up till i put the duals on. have slooshing sound in heater core, moisture coming ou both sides of exhaust left heaver than right. no coolant in oil or oil in the raditor. during winter or summer temp gage shows only about 80 degrees and hard to get heat during winter. is it possible that the heater coree is clogged and is causing all my problems? :?: :( :([/quote:ee124ee2b2]
The cooling system is nowhere associate with the exhaust system
Have you check the thermostat? if its completely closed you won't have anything in the heater core
probably the slooshing sound is boilover-you sure your temperature gauge is not misleading you-could be out of calibration.
Have the cooling system block and pressure tested-this will tell you something if its burning internally about heavy moisture coming out on one side.
Sounds like a blown headgasket
Sep 2, 2007 at 10:07 PM
HOTDEAL
  • 6 POSTS
[quote:853cf52891="hotdeal"]1994 c1500, 4.3l eng, 128k miles, 2 wheel drive, silverado package, heavy duty towing package. cut out cataiytic converter, put on duals with glass pack mufflers on duals. have started loosing coolant.problem did not show up till i put the duals on. have slooshing sound in heater core, moisture coming ou both sides of exhaust left heaver than right. no coolant in oil or oil in the raditor. during winter or summer temp gage shows only about 80 degrees and hard to get heat during winter. is it possible that the heater coree is clogged and is causing all my problems? :?: :( :([/quote:853cf52891]
CKED THERMOSTAT, ALSO PULLED ALL THE SPARK PLUGS, NO INDICATION OF COOLANT GETTING INTO TO PLUGGS, CKED WATER PUMP NO INDICATION OF LEAK, CKED ALL HOSES NO INDICATION OF THEM LEAKING :?: :cry:
Sep 5, 2007 at 11:55 PM
  • 75,988 POSTS
[quote:2902062aae="hotdeal"][quote:2902062aae="hotdeal"]1994 c1500, 4.3l eng, 128k miles, 2 wheel drive, silverado package, heavy duty towing package. cut out cataiytic converter, put on duals with glass pack mufflers on duals. have started loosing coolant.problem did not show up till i put the duals on. have slooshing sound in heater core, moisture coming ou both sides of exhaust left heaver than right. no coolant in oil or oil in the raditor. during winter or summer temp gage shows only about 80 degrees and hard to get heat during winter. is it possible that the heater coree is clogged and is causing all my problems? :?: :( :([/quote:2902062aae]
CKED THERMOSTAT, ALSO PULLED ALL THE SPARK PLUGS, NO INDICATION OF COOLANT GETTING INTO TO PLUGGS, CKED WATER PUMP NO INDICATION OF LEAK, CKED ALL HOSES NO INDICATION OF THEM LEAKING :?: :cry:[/quote:2902062aae]
Disconnect heater hose from engine side and try flushing it out
Sep 6, 2007 at 12:50 AM
HOTDEAL
  • 6 POSTS
[quote:deb0ee7a91="rasmataz"][quote:deb0ee7a91="hotdeal"][quote:deb0ee7a91="hotdeal"]1994 c1500, 4.3l eng, 128k miles, 2 wheel drive, silverado package, heavy duty towing package. cut out cataiytic converter, put on duals with glass pack mufflers on duals. have started loosing coolant.problem did not show up till i put the duals on. have slooshing sound in heater core, moisture coming ou both sides of exhaust left heaver than right. no coolant in oil or oil in the raditor. during winter or summer temp gage shows only about 80 degrees and hard to get heat during winter. is it possible that the heater coree is clogged and is causing all my problems? :?: :( :([/quote:deb0ee7a91]
sorry haven't got back,but I am a truck drive n not home much. will be in a week or 2 will do it then n report back
CKED THERMOSTAT, ALSO PULLED ALL THE SPARK PLUGS, NO INDICATION OF COOLANT GETTING INTO TO PLUGGS, CKED WATER PUMP NO INDICATION OF LEAK, CKED ALL HOSES NO INDICATION OF THEM LEAKING :?: :cry:[/quote:deb0ee7a91]
Disconnect heater hose from engine side and try flushing it out[/quote:deb0ee7a91]
Sep 15, 2007 at 12:52 AM
HOTDEAL
  • 6 POSTS
[quote:1d556f4ef1="hotdeal"][quote:1d556f4ef1="rasmataz"][quote:1d556f4ef1="hotdeal"][quote:1d556f4ef1="hotdeal"]1994 c1500, 4.3l eng, 128k miles, 2 wheel drive, silverado package, heavy duty towing package. cut out cataiytic converter, put on duals with glass pack mufflers on duals. have started loosing coolant.problem did not show up till i put the duals on. have slooshing sound in heater core, moisture coming ou both sides of exhaust left heaver than right. no coolant in oil or oil in the raditor. during winter or summer temp gage shows only about 80 degrees and hard to get heat during winter. is it possible that the heater coree is clogged and is causing all my problems? :?: :( :([/quote:1d556f4ef1]
CKED THERMOSTAT, ALSO PULLED ALL THE SPARK PLUGS, NO INDICATION OF COOLANT GETTING INTO TO PLUGGS, CKED WATER PUMP NO INDICATION OF LEAK, CKED ALL HOSES NO INDICATION OF THEM LEAKING :?: :cry:[/quote:1d556f4ef1]
Disconnect heater hose from engine side and try flushing it out[/quote:1d556f4ef1][/quote:1d556f4ef1]
Sep 15, 2007 at 12:53 AM
