running for some time and you shut it off it will not start again?
POPINCORK
The truck starts fine when you first start it. After running for some time and you shut it off it will not start again. You get absolutely nothing, it won't crank. However, if you let it sit for and hour to an hour and a half it will start right up.
Sep 6, 2007 at 10:03 AM
  • 75,988 POSTS
This is a classic starter problem but to be sure this guide will help us
Jun 28, 2021 at 2:59 AM
WILDFIREV9
  • 49 POSTS
My 86 Chevy chassis motorhome had the same problem. After changing the starter solenoid and adding the heat shield (recommended for big blocks especially), problem was still there.
Found out it has a 'hot start soleniod'. Looks like a ford fenderwell mounted starter soleniod. After changing it, my motorhome starts everytime no matter what.
Hope this helps, VIC
'wildfirev9'
  • 75,988 POSTS
Disable the ignition coil by removing the coil wire -Now hold key to start position and look for power at the starter solenoid small terminal with a purple wire -Power there-replace the starter. No power backtrack to the ignition switch. See below
https://images.2carpros.com/forum/automotive_pictures/12900_starter_15.jpg
