99 tahoe vibrates
BLAZERRF88
99 chevy tahoe 114,000 miles
Irecently replaced the ujoints on the driveshaft and still have a vibration coming from the rear of the vehicle. could this be a wheel bearing or is there something else I should look at first? I did line up the driveshaft by marking the joints before I removed it and I did not lose any of the weights. would appreciate any help I can get
Thanks
Jul 30, 2006 at 1:34 PM
DEMEARSJR
  • 110 POSTS
To check your wheel bearings raise the rear end of the vehicle and put 1 hand on the top of the tire and 1 hand on the bottom.
If it wiggles it's a bearing.
Look for uneven tire wear as well.
Jul 30, 2006 at 4:21 PM
