1998 Chevy S-10 High Idle
MJE_IGGY
1998 Chevy S-10 2WD, STD Transmission, 96000 miles. I had been having problems with my AC. When running the AC and after having pressing the clutch the RPM's would jump to 3-4000. When attempting to drive after that point the truck would stall. I remedied this by simply not using the AC and leaving the dial on heat. But now I am experiencing slight raises in idling when the clutch is pressed. It will raise to just over 1000 and remain that way for a few seconds and then return to normal. I have just recently had the Service Engine light come on and I have a TPS reading. 2 questions: 1) what is wrong with the AC and 2) could this new reading stem from that problem?
Jul 6, 2006 at 6:22 AM
MIKEYBDMAN
  • 623 POSTS
First off, the Throttle Position Sensor can cause your problem. The Vehicle Control Module calculates fuel delivery based on throttle valve angle. A broken or loose TP Sensor may cause intermittent bursts of fuel from an injector. This may cause unstable ide because the VCM detects the throttle is moving.
Another place to look is the Idle Air Control valve located on the throttle body. This unit control the engine idle speed during changes in engine load.
Hope this helps.
Jul 7, 2006 at 1:57 PM
Suggested Repair
Test the throttle position sensor for looseness or failure, since it can cause unstable idle and intermittent fuel bursts. Also inspect the idle air control valve on the throttle body, which controls idle speed during engine-load changes.
Conversation Summary
The owner of a 1998 Chevy S-10 reports RPM spikes and stalling when using the AC and pressing the clutch, followed by a milder idle increase with the clutch and a service engine light with a TPS reading. The expert says a faulty or loose TPS can cause unstable idle and recommends also checking the idle air control valve.
