98 chevy s-10 blazer 4.3L v6 Vin code W
TEAMSTER174
What piston need to be at TDC on the compression stoke in order for my engine to be timed correctly?
I just installed a new engine and it will crank over but no start.
Apr 20, 2007 at 6:22 AM
DE3N8FAN
  • 15 POSTS
#1 piston,rotor contact in distrubtor facing 1 plug wire contact.loosen distrubtor shaft securement bolt slightly (enough to twist distrubtor slightly in eather direction)if it tries to start a slight twist one way or the other could help.good luck
Apr 20, 2007 at 12:23 PM
LES DANE
  • 52 POSTS
don't think the timing is adjustable. you can set the distributor to #1 but not turn it.
Apr 24, 2007 at 10:02 AM
