97 Monte Carlo No A/C
TITUSM1
I have a 1997 Chevy Monte Carlo LS, 3.1L, Automatic, with 150,000 miles on it. The car has a A/C leak for about a year, that nobody can find it. I have been using over the counter A/C refills. The problem is when I tried to use the over the counter refill this time the car has not been producing cold air. There is a guage on the refill and it shows that the system is at half way in the green area. maybe i have been using the wrong port. What port does the refil go to, both of my caps are black. Thank You for your help.
May 11, 2007 at 12:19 PM
MIKE H R
  • 3,094 POSTS
check out the web site, interdynamics r134a, go to auto air conditioninga/c retrofitting faqs. they give the high sides and the low sides and where they are located, there is also a leak detector available.
May 13, 2007 at 4:09 AM
