Thanks
97 Chevy astro van coolant leak
Thanks
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
For a similar leak, have its source traced before authorizing parts replacement; include the intake-manifold area in the inspection. Avoid driving with an active coolant loss and do not open the cooling system while hot.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Do you have a rear seat heater? Check those 2 hoses that run underneath the van from the p side to driver side and into the heater core from underneath the van
Discussion summary
A 1997 Chevrolet Astro 4.3L leaked coolant near the rear of the engine, above the transmission connection. The owner reported that the visible hoses and recently replaced water pump did not appear to be leaking.
Reported outcome: The owner reported that the leak came from an intake-manifold gasket and that the heater core checked out.
The discussion does not document the diagnostic method, gasket replacement or a post-repair leak test. The earlier heater-hose suggestions were not the owner's reported diagnosis.
