95 Chevy S-10 2.2l 135,000 miles
PASSINGFOOL
  • 1995 CHEVROLET TRUCK
I am leaking coolant out of the water pump assembly. I am not getting heat in the cab. Is the pump defective, how do I test it?
Saturday, February 3rd, 2007 AT 5:29 PM
MIKE H R
  • 3,094 POSTS
When a water pump starts to go bad there is a small hole in the back. That starts to leak letting you know water pump is starting to go bad. You can get a pressure tester at local auto store and check for leaks. The no heat could be it is low on antifreeze.
Monday, February 5th, 2007 AT 8:31 PM
