Transmission fluid was just added and all other fluids are fine. The coolant is not low although the "low coolant" light is on almost all the time.
Fuel injectors were replaced and many other things on the car including the coolant sensor and heater core.
Also, the heat is no longer blowing as powerfully as it used to. It used to blow out powerfully but now it's just silent.
What could it be? (We thought transmission fluid would help it, but that wasn't it.)
SPONSORED LINKS
Sunday, March 4th, 2007 AT 11:07 AM
