94 Chevy z71 check gages light
STEEL BILL
  • 6 POSTS
I have a 94 Silverado Z71 with a 5.7 v8 and 187,000 miles on it the engine has less than 70,000.The check gages light wont go off,oil press. is 40psi,temp is 180, Volt is 13.0 and yes the gas is full.I pulled the oil sending unit and used a mech. gauge and it reads the same as the dash.And the computer shows no stored codes.The light came on and stayed once before a few months ago but went off by itself Truck runs fine , power is good, everything works but the light is driving me nuts
Aug 21, 2007 at 7:39 PM
CLY
  • 308 POSTS
Sounds like all the gauges are reading correctly. I would say that there is a problem in the cluster. I have seen a few that do that but the cause for the check gauges message was the low fuel light would not go out. I had to remove the cluster and send it out for repair.
Cly
Aug 21, 2007 at 9:37 PM
STEEL BILL
  • 6 POSTS
Thanks for the reply Cly I'm locating a replacement cluster to try.I'll let you know how it turns out.
Aug 23, 2007 at 8:25 PM
