I have a 94 chevy truck with a 4.3L it has 81,000 miles on it it's got a auto trans. And its two wheel drive. I was driving home the other day and while sitting at a stop light it missed 3 times and died. I got it started and limped it home. The cat. Coverter was very hot. The check engine light came on 3 times and not for more than 4 or 5 seconds. It has been on a diagnostic comp. And it showed nothing. It misses really bad in fact it will hardly run and wont really pull its self. I have removed the converter, changed the coil, pickup coil, modual, plug wires, dist. Cap and rotor. The plugs are only 2 years old. And I changed the fuel filter. When I can get it to idle it idles very smooth, how ever it will only idle every now and then, you have to work at it hahaha. Any idea?
SPONSORED LINKS
Wednesday, May 30th, 2007 AT 10:18 PM
