[quote:2940a18570="carundell"][quote:2940a18570="michelle williams"][quote:2940a18570="carundell"]Hey michelle,
Sorry, meant to say the ignition lock cylinder and key have to be a matched set as they send the electrical signal to the anti-theft module/pcm to enable starting. There has been an issue with the lock cylinder wiring breaking after age and causing that condition.
Chris[/quote:2940a18570] How do get them matched set? Can i or do i need to replace the lock cylinder?[/quote:2940a18570]
Michelle,
2 choices. 1. Take the vehicle to a trusted shop and get an accurate diagnosis and fix. 2. You can do the lock cylinder. To do this yourself, 1st I'll send along the repair procedure. 2nd, contact your local GM dealer, explain to them that you need a new lock cylinder and key ( you may need to give them the vin #), they may also need to examine/test your key for the proper resistance value(yes! there is a tiny resistor in your key) and get the proper parts. The replacement of the cylinder isn't too hard a job if you follow the procedure! Check your email and let me know if you need any assistance!
Chris[/quote:2940a18570] I got the lock cylinder and key but the key is a normal key unlike the key that came with the car the guys at the parts store said it bypasses the anti theft system is this true are they just feeding me a line ?
Feb 4, 2007 at 10:09 AM
