Sounds like the fan replacement you did has increased the heat in the system. Could be that that fan turns a little slower, who knows. I would first see if I could find a new correct fan. Junk yards can be useful, but remember the fans you get from them are 14 years old for your car.
I would atleast call the dealership and see what a fan costs, then go to www. Gmpartsdirct. Com and see if they sell your fan. If you cant find it, email them and give them make model and VIN number and ask if they have a part number for you to order one.
You will probably find that a new fan will help some, but it sounds like that model may have had a flaw in the design of the cooling system.
Give your local dealership a call and see if they have any kind of recall or mod for that engine.
As for your overheating problem. What are the symptons? Does it creep up slowly? Does it get hot to start with, then cycle down a bit then go back up? Are you having to add fluid?
SPONSORED LINKS
Thursday, July 13th, 2006 AT 6:43 PM
