Auto starts but surges and runs really rough. Replaced plugs and wires. Thinking fuel pump or fuel pressure regulator. Any other ideas?
Jan 21, 2007 at 4:29 AM
MECHPRO18
MEMBER
check you EGR valve this is what controls the vacuum and if it is not that then possibl there is water in the fuel tank.
Mar 11, 2007 at 7:37 PM
✓Experienced Mechanic
[quote:574412fbfc="sacrilidge06"]Auto starts but surges and runs really rough. Replaced plugs and wires. Thinking fuel pump or fuel pressure regulator. Any other ideas?[/quote:574412fbfc]
Check the fuel pressure before you go into the spider unit
