1991 Chevrolet K1500 Stalls No Fuel
GEORGERZECZKA
I have a 1991 k1500 quad cab. I filled it up with gas and drove 30 miles to the dmv. When I was driving back, before I got on the highway, the truck started to stall and then it did. Now it tries to start but when I give it gas it sounds like its not getting any fuel. The truck will not idle on its own. Like it is starving for fuel.The engine is a 305 tpi. What can be the promblem. Oh yeah no promblems with this before first time this has happen. Like this is not a on going promblem. Thank you for your time
Nov 15, 2007 at 8:28 AM
PEAR69
  • 1,482 POSTS
How many miles are on it? Lets start here change the fuel filter and the air filter. BTW Filling up with gas probably has nothing to do with the problem.
Let me know how you make out.
Nov 16, 2007 at 1:37 PM
Suggested Repair
Replace the fuel filter and the air filter, then recheck idle and throttle response. The recent fill-up is probably unrelated.
Conversation Summary
The owner of a 1991 Chevrolet K1500 with a 305 TPI said the truck stalled after a fill-up and a 30-mile drive. It cranks but will not idle and seems to starve for fuel when the throttle is opened. This was the first occurrence. The expert asked for the mileage and recommended changing the fuel filter and air filter, noting the fill-up is likely unrelated.
