89 chevy k2500 no fuel sening
2012 CHEVROLET TRUCK
BOWTIEXGUY
i have a 1989 chevy k2500 with 150k miles on a 5.7l, 350. I was out mudding and the truck got stuck. the truck was not submerged at all but at a steep angle. The truck was left to idel for a minute then it died. When i went to start it, it would not, opened the hood and there was no feul sparying from injectors. My gas gaudge isnt the best so i thought it was out of fuel, but i added 2 gallons and tryed to start it again and it would not. any info?
Sep 2, 2007 at 9:59 AM
[quote:80c4102a4b="bowtieXguy"]i have a 1989 chevy k2500 with 150k miles on a 5.7l, 350. I was out mudding and the truck got stuck. the truck was not submerged at all but at a steep angle. The truck was left to idel for a minute then it died. When i went to start it, it would not, opened the hood and there was no feul sparying from injectors. My gas gaudge isnt the best so i thought it was out of fuel, but i added 2 gallons and tryed to start it again and it would not. any info?[/quote:80c4102a4b]
I got you PM-turn key On do you hear the fuel pump? you don't -check for power at F/P connector-no power there-check relay/fuse.
Check all connections at distributor-find the CPS if it has one double check it. Pull the coil wire and ground it-do you have spark?
Sep 2, 2007 at 11:43 AM
BOWTIEXGUY
[quote:555e6fb8f2="rasmataz"][quote:555e6fb8f2="bowtieXguy"]i have a 1989 chevy k2500 with 150k miles on a 5.7l, 350. I was out mudding and the truck got stuck. the truck was not submerged at all but at a steep angle. The truck was left to idel for a minute then it died. When i went to start it, it would not, opened the hood and there was no feul sparying from injectors. My gas gaudge isnt the best so i thought it was out of fuel, but i added 2 gallons and tryed to start it again and it would not. any info?[/quote:555e6fb8f2]
Check all connections at distributor-find the CPS if it has one double check it. Pull the coil wire and ground it-do you have spark?[/quote:555e6fb8f2]
hey man, thanks for the reply, i just went out and checked and i could NOT hear the fuel pump. But i do have spark. i can pour gas into throtle body and it will run for a little bit. Im gonna go out and check connections. ill post back if i dont get it. thanks again for the help. post back with any more ideas. thanks
Sep 2, 2007 at 12:08 PM
