69 chevy PU with ticking sound
1969 CHEVROLET TRUCK
LDREAMAZ
I recently replaced the fuel pump in the truck but i have a ticking sound under the hood. I heard it when i reversed and either when i am idle or sometimes i hear it when i accelerate. What should i be checking?
Aug 9, 2007 at 4:18 AM
GARFIELD
  • 197 POSTS
You may want to look at the fans relay and wiring. First I would look at a failed relay causing it to stay on. Secondly I would look at the wiring being shorted but that would be something you would want a repair center to do if you do not understand electricity.
May 20, 2007 at 6:41 AM
[quote:441bd4f368="Ldreamaz"]I recently replaced the fuel pump in the truck but i have a ticking sound under the hood. I heard it when i reversed and either when i am idle or sometimes i hear it when i accelerate. What should i be checking?[/quote:441bd4f368]
1st I will check the heat shield maybe it got loose-or something else loose upfront if not these could be coming from the valvetrain-meaning valve lash adjustment or a leakdown problem with lifters.
Aug 11, 2007 at 10:28 AM
