TJ SCAFER
I HAVE A CHEVY 350 30 OVER ITS IN A 77 PICKUP IT HAD SIGNS OF A BLOW HEAD GASKETS STEAM WATER IN OIL.
I REPLACED THEM BUT DIDIT CHECK THE HEADS. I STILL HAVE THE PROBLEM I THINK ITS THE HEADS BECAUSE IT S NOT TO ON COMMIN FOR THAT . BUT IS THERE A CHANCE THE BLOCK IS BAD
Apr 6, 2007 at 2:29 PM
MIKE H R
  • 3,094 POSTS
where the heads you put on used or had they been machined? have the system pressure checked, if you have the heads off look for hairline cracks by the top of the cylinder. has the truck run overheated? check the heads to see if they are warped.
Apr 7, 2007 at 3:00 AM
