2008 Chevy Truck Turn signals
24,600 MILES • V8 • 4WD • AUTOMATIC
FGRIPPA
I purchased a front and rear after market bumpers from Fab Four bumpers. The front has running/turn lights and driving lights mounted in it. I connected the lights per drawing and color codes. Everything is in working order, signals worked, running lights work. The next day my right turn arrow started flashing very fast so I thought a bulb had burned out. All bulbs work fine. Then sometimes the left would blink very fast, still all signal are lit and working. I double checked connections and wiring. Any thoughts? Everything lights as it should they just blink rapidly.
Feb 9, 2009 at 9:26 AM
DON OLIVER
  • 101 POSTS
if all the bulbs are lighting up when they're supposed to, I would suspect the flasher doesn't like the extra lights and you might try a heavy duty flasher.
Feb 9, 2009 at 9:38 AM
