2006 Chevy Truck HEATER BLOWER CONTROL
STEVE GIES
Electrical problem
2006 Chevy Truck V8 Four Wheel Drive Automatic
GM HISTORY ON ON THIS COMMON PROBLEM
Dec 3, 2009 at 10:51 PM
  • 110,248 POSTS
What problem are you having?
Dec 22, 2009 at 1:30 AM
STEVE GIES
THE HTR. RESISTOR FOR MY 2006 , 05,04 &1999 TRUCKS HAVE TO BE REPLACED ALMOST EVERY YEAR AT APPROX.$ 70EA. IS THERE ANY OTHER WAY TO BE THIS???.....SPECIFIC PROBLEMS ARE THE INTERMITTIN AND OR LOSS OF SPEEDS 1-4, AND MOST OF THE TIME THE HIGH (#5)SPEED WILL BE THE ONLY ONE TO WORK. I HAVE SEEN THIS TYPE OF PROB. ON MANY ,MANY, GM PRODUCTS.
Dec 24, 2009 at 2:39 AM
  • 110,248 POSTS
That is typical. The highest setting doesn't require the power to be lowered (resisted). As a result, the highest will usually work. Believe me when I say it isn't just GM. THey all do it. THe most common reason is the motor draws too many amps causing the resister to burn up.
Dec 24, 2009 at 12:04 PM
