2006 Chevy Truck electric
DUALLYDONDON
Electrical problem
2006 Chevy Truck 6 cyl Two Wheel Drive Automatic 15.000 miles
the pickup had the ingnition switch replaced after vandalism,,,the switch worked well for a couple of days then became difficult to turn, it still works but developed some resistance,,two days after the replacement the ABS light and the parking warning lights come on and stay on, also the heater and ac do not work, fuses all check out good,are the problems related???
Jan 20, 2009 at 1:48 PM
  • 110,248 POSTS
Hi:
Based on your description, it sounds like the ignition switch itself was damaged. That is where I would start.
Jan 22, 2009 at 7:13 AM
