2005 Chevy Truck front axle area making squawking noise
DODGE360
Noises problem
2005 Chevy Truck Four Wheel Drive Automatic 200000 miles
front end makes squawking noise when stopping and then when you first move but not when you normally drive.
Jun 7, 2010 at 5:22 AM
MHIMMEL
  • 30 POSTS
This noise could be coming from either your brakes or your wheel bearings. If its the brakes you'll have to have new brake pads and possible new rotors put on. If it's the wheel bearings you'll have to take it to a mechanic to have that fixed. My guess is it's the brakes since you said it happens when you stop. Hope this helps!
Jun 24, 2010 at 4:19 AM
