2005 Chevy Truck AIR BAG SERVICE AND ABS LIGHT
HUNTER9922
2005 Chevy Truck V8 Four Wheel Drive Automatic
HOW DO YOU "SERVICE THE AIR BAG? THE LIGHT STAYS ON ALL THE IME. I TRIED UNHOOKING THE BATTERY FOR A WHILE TO RESET THINGS, BUT THAT DID NOT WORK. ALSO, I CHANGE MY RIGHT WHEEL HUB ASSEMBLY BECAUSE IMY ABS LIGHT WAS ON AND I CHECKED IT WITH A DIAGNOSTIC METER AND IT SAID THE WHEEL SPEED SENSOR WAS BAD. HOWEVER, AFTER I INSTALLED THE NEW ONE, IT STAYED ON AND SAID THE SAME THING. HOW CAN I FIX THIS PROBLEM. THANKS.
Jul 7, 2010 at 8:15 AM
HMAC300
  • 48,601 POSTS
you might have a battery that isn't to good making the service air bag on. but it should be scanned, your scanner may not be able to do that, dealer ones can. when you replace a part on the abs or engine you need to reset and erase the code after doing so or it will stay on. if it still is on after doing this then you might have a wiring problem.......
Jul 10, 2010 at 6:24 AM
