2005 chevy impala heater controls
RANDYW523
my a/c works great but when i go to heat it only blows hot on passerager side..blows cold on drivers side..it has slide controls for temp ..cold down/hot up ..if i move pass. side slider up heat works down cold works..if i move drivers side slider up it blows cold if i move slider down it also blows cold..is there something i need to check? don't know much about the newer cars
Sep 25, 2006 at 10:11 AM
DAWNRAE_82
I have a 2004 Chevy Impala and my car does the same EXACT thing. I asked someone at a shop once and he said it might be the control module ($400-$600 to replace)...
but I joined this forum to see if anyone else knew what was going on...
I feel your pain/frustration/disappointment.
Oct 2, 2006 at 7:23 PM
LEHUCK69
I too have 2004 impala that has that same problem. I wish I knew someone who knew what the problem was. Has anyone figured it out yet?
Oct 3, 2007 at 9:34 AM
DIAJIM
[Same problem its been a while for you did you solve the prob.
Nov 23, 2007 at 12:40 PM
