2004 Chevy Truck
PINKY123
Engine Performance problem
2004 Chevy Truck 6 cyl Two Wheel Drive Automatic
vehicle will run awhile then stall,sometimes starts, sometimes dont. acted like running out of fuel, changed fuel pump and filter, ran about one hour and stalled, will not start,acts like no fuel also, will not set a code
Jul 31, 2008 at 12:54 PM
MASTERTECHTIM
  • 4,750 POSTS
spray starter fluid into intake and see if it will run. if it starts and runs then double check the wiring connector to the fuel pump to see if its lightly melted and also check the ground connection on the frame for corrosion.
Jul 31, 2008 at 11:42 PM
