2004 Chevy Tahoe hesitates when starting?
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
First clarify whether the starter turns slowly or the engine cranks normally for longer before firing. Ask the shop to test the relevant starting or fuel system after a comparable cold soak.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis.
Discussion summary
A 2004 Tahoe with 37,000 miles hesitated during cold starting but ran normally afterward and started normally when warm. Contributors suggested allowing fuel-pump priming before cranking.
Reported outcome: The owner planned to try the suggestion; no result was reported.
The description is ambiguous between slow cranking and delayed firing. Fuel-pressure loss was another owner's experience, not a measured finding on this Tahoe.
