2003 Silverado Dash Lights
2003 CHEVROLET TRUCK
KENH
How do I replace the dash/instrument light bulbs in my 2003 Chevy Silverado? The A/C temperature slider light is burned out. My local Chevy dealer says the lights are not replaceable and I must replace the entire A/C dash module at $160. This seems ridiculous...
Jan 13, 2006 at 4:27 PM
KENH
Update: I removed and disassembled the A/C instrument pod. The light bulbs are soldered to a PC board. If I wiggled the (tiny) light socket, the bulb lights up intermittently. The solder points are good, so I assume the bad connection is in the socket, which is not repairable. Does anyone out there have a 2003 Silverado instrument diagram with the bulb spec for the A/C module? I plan to solder in new bulbs..
Jan 14, 2006 at 11:03 AM
