2003 Chevy Truck Chevy truck misfire
2003 CHEVROLET TRUCK
JUSTIN BEELER
Engine Performance problem
2003 Chevy Truck 6 cyl Two Wheel Drive Automatic
03 Chevy 1500 with a 4.3. Last night was on way home and it started missing bad.
The right side plugs were all fouled. It threw a P0300 code. Multiple cylinder missfire. Changed the cap, plug, wires, and distributer. Also the fuel pump. And cleaned the O,2 sensors and even tryed it without it plugged in.
Does anyone have any ideas or suggestions?
Jan 24, 2009 at 7:01 AM
BILLYMAC
  • 2,204 POSTS
which fuel system do you have. is your eng vortec?? please let me know and i will help you thanks billymac
Jan 24, 2009 at 7:05 AM
JUSTIN BEELER
yes it is a vortec
Jan 24, 2009 at 7:21 AM
JUSTIN BEELER
anyone?
Jan 24, 2009 at 8:59 AM
BILLYMAC
  • 2,204 POSTS
hi justin. the vortec has a fuel injection controller under the plantum .it actually distributes fuel through poppet valves. when these things fail they will foul all the plugs on one side or the other. this part is a cpl hundred dollars and the plantum has to be removed . if you remove the plantum you will most likely find raw fuel lying inside the valley. this is an indication the orings in the poppet valves are bad.good luck billymac
Jan 24, 2009 at 12:29 PM
JUSTIN BEELER
It ended up being the catalytic convertor but thanks
Jan 26, 2009 at 8:42 AM
