2003 Chevy Truck
2003 CHEVROLET TRUCK
63,000 MILES • 6 CYL • 2WD • MANUAL
1SLIM1
i replaced the battery and now it starts and dies after 2 seconds.
Jan 3, 2008 at 5:52 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
first remove the air intake hoses and have someone start the car and give it half throttle, after it starts to die, give it a little bit of starting fluid, if it stays running untill it runs out of starting fluid then you should check the fuel pump.
does it fire right back up after it dies?
Jan 3, 2008 at 7:29 PM
