2003 Chevy Truck
MATTJ08
Noises problem
2003 Chevy Truck Four Wheel Drive Automatic
what would cause a grinding noise in my front left end besides brakes
Aug 28, 2008 at 4:57 PM
  • 31,937 POSTS
Hi there,
if this noise is while the vehicle is moving, the only other thing would be a faulty or collapsed bearing, or may be something has lodged up behind the brake backing plate & the brake rotor, often you can get a stone wedged and it will grind away then fall out, check this out.
Mark (mhpautos)
Aug 28, 2008 at 8:40 PM
