The speedometer is acting like it wants to work, but most of the time, it doesn't
DODAVIS
the speedometer is acting like it wants to work, but most of the time, it doesn't. Once, it even got stuck. I called the repair shop and they said that they would replace the speedometer and it would be $500 + tax. I am in college and this is a little steep. What do you propose? The person who had the car before me really did not take care of the car.
Apr 5, 2007 at 6:21 AM
BYMECH
  • 8 POSTS
just posted with the same problem...vss was good, turned out to be cluster in dash which I got at salvage yard for $35. The vss controls shifting and cruise control as well as speedometer. My car shifted fine and cruise control worked. bought a service book and attempted to check for voltage going to speedo cluster( at dash). couldn't figure which wires to read so took a chance at salvage yard. solved problem. Now only problem is new cluster shows wrong mileage!...oh well, can't win em all! this video will show you how.
https://youtu.be/_HEC44xENxw
Apr 12, 2007 at 8:25 AM
