2002 Chevy Truck 4x4 locked in 4h
103,000 MILES • V8 • 4WD • AUTOMATIC
CHARLES ELLIOTT
which actuator is likely not allowing my truck to shift out of 4H to 2H, the transfer case actuator or the differential actuator. I have a service 4wd light on the message center. The transfer case actuator makes a harsh buzz when actuated and the diff. actuator sounds normal. Could it be another issue?
Jan 11, 2008 at 8:47 AM
MASTERTECHTIM
  • 4,750 POSTS
the one on the transfer case fails alot. you should really have it checked out by a repair shop so they can retrieve the codes from the transfer case control module.
Jan 11, 2008 at 8:54 AM
